WANTED: K11 1.3 LX Alternator Belt tension bracket
Just sheared the tension bold on my alternator bracket trying to get that and the pinch bolt undone. I figured it'd be easier to break out and replace the whole bracket rather than try and drill out the tension bolt.
Does anyone have the bracket for sale?
Problem solved. I finally managed to get the siezed bolts to give and took the bracket off, from there on it was easy to remove the sheared screw from the tension block and a quick trip to screw fix solved the problem. Didn't anticipate it taking quite so long to change a belt but job done. Thanks anyways!
