Vauxhall Corsa SXI Alloy Centre Bore
friend of mine is about to buy an R reg micra, and has also got a set of corsa sxi alloys of his old car.
what he wants to know is...will they fit??
pcd is 4x100 <- they will fit
offset ?? <-dosnt know
centre bore ??.? <- also dosnt know.
cheers
cheers or that, didnt know how spacer work, thought centre bore was the same size...or larger than the part of the axle and if it was smaller then they would need a bit of it machined out...i think if i remember rightly, its 56.6mm centre bore and micras need 59.1 so they would need 1.5mm all the way round...or there abouts.
how do spacers work???
it's just a 3mm metal disc with a massive centre bore and loads of holes in it for fitting to any car with 4 or 5 stud
