CMF_k11.3tc » CMF Member Spain Member since: Posts: Mar 2, 2013 #1 i want to set the valves in my CG13DE monster. How do i do that and where can i find info about that ? Thanks in advance
CMF_frank2 » CMF Member birmingham, United Kingdom Member since: Posts: Mar 2, 2013 #2 they are a bucket and shim design, have you measured yours ?
CMF_Danvillan » CMF Member Mulgoa, NSW, Australia Member since: Posts: Mar 2, 2013 #3 haynes manual will give you the info you need. Took some photos of the spec and procedure hopefully you can read it as the resolution is limited on the uploads. Attachments 83103.jpg 116.2 KB · Views: 17
CMF_Danvillan » CMF Member Mulgoa, NSW, Australia Member since: Posts: Mar 2, 2013 #5 . Attachments 83105.jpg 115.6 KB · Views: 28
CMF_Danvillan » CMF Member Mulgoa, NSW, Australia Member since: Posts: Mar 2, 2013 #6 Hopefully that helps you out. Attachments 83106.jpg 116.8 KB · Views: 18
CMF_k11.3tc » CMF Member Spain Member since: Posts: Mar 3, 2013 #7 THANKS !!! ILL POST FOTO,S WHEN ILL START WITH IT !!! I THINK THE SHIMS ARE GOOD AVAILEBLE AT ANY CARPART STORE ?
