valve clearances MA10
Hi All
iam searching for valve clearances to a micra k10 -87 engine MA10
I have only found valve clearance to MA12 here, are the cleareance same?
Hi
the valve clearances for the MA10 are
0.25mm inlet
0.30mm exhaust
they should be done when the engine is hot.....Liam
If you want the engine to sound a bit sweeter you can do 0.20mm on the inlet and 0.22mm on the exhaust . You might get small bit of unstable idle but at least it does'nt sound like a bag of spanners. Tappet noise is for Ford push rod engines lol(Y)
