Vacuum lines
CMF_david (2)
Can anyone tell me exactly where the vacuum tubes are supposed to go from the carbon cannister?
In particular where is the top one supposed to go? does it go to the valve on the engine and is the otherside of the white valve on the engine supposed to be connected to a pipe that goes to the airbox and also the manifold?
If someone in perth can show meet up with me to show me their car it would be appreciated.
CMF_Rudy
first the top one, it goes to a y piece which then one branch goes to throttle body and the other plugs just behind the dizzy/thermostat housing.
bigger one underneath, this goes to back of inlet manifold.
one on side, it goes into pipework below fuel filter(further down)
CMF_david (2)
Where does the little pipe that fits along the bottom of the airbox go? How is it connected to these pipes? Does it also go down to just behond the dizzy/thermostat housing?
