will fit any vehicle equipped with vacuum hoses. Almost every single vehicle has multiple vacuum lines.
Locate the vacuum line, which is connected to the air intake manifold of the engine. This is a 1/4'†black hose with vacuum pressure inside it. If you are not sure which hose it is, pull out one end of the assumed hose from its original connection and feel for vacuum pressure
so could this be the breather hose?
