urgent wheel help !!!
bout a set of 14 inch alloys for my micra daisy's off an mx5 the hub bore on the wheels is 50mm and the micra hub is 60 is there any way I can bore them out ?!?!
Best way is to get them professionally machined, I tried doing it myself but went through £25 of drill bits and didn't even get one wheel done. No shortcuts get a pro ahha
Agree with above. You will spent more money and time trying to do it yourself for results that may not be perfect.
I had some Polo steels machined out for £5ea.
Some places charge £25 per wheel though!
Wow, sod that.
I rocked up to my local engineering shop and they did it there and then.
This place didn't specifically so wheels and did say to me "it's at my own risk". Which is why it was so cheap.
ive done it my self now fits like a glove :p ! just used a drill saw bit to take the main chunk of allot out and then once it was pretty close to where it had to be just ran a hole cutter 60mm down it to make it a straight cut worked wonders
