Bit of background, we are day 30 into driving a
K12 998cc Nissan Micra Petrol from Edinburgh > Mongolia. We are currently in the famous country of Kyrgystan (just south of Kazakstan) but we are having severe difficulties with the car loosing power.
Car will begin kangarooing and immediately loose all power and essentially be unable to move above 5mph. Rpm in neutral can go to 7,000rpm or above but by bringing the clutch up all power evaporates.
When:
The problem normally occurs during acceleration or when the engine load increases from a hill.
During the past 5 days the problem has increased in frequency. The car does less kangarooing and more complete loss of power.
We have never experienced the problem until after driving for 6hours (so usually occurs during the middle of the day).
Often the problem will dissipate in the evening (air temperature decreases)
The problem first occurred on 5th August after 5hours of driving, shortly after refuelling from a jerry can of 90 or 93 octane fuel. We drained the fuel tank and replaced it with 95octane fuel but problem persisted
Remedies:
5days ago the problem could be solved by flicking the ignition on and off, by keeping a foot on the accelerator you could feel the power and revs immediately increase and the car would appear 'back to normal'. -this no longer really works
The only true fix for the problem has been to leave the car turned off for as long as possible before continuing.
For example, parking for 15 minutes will allow the car to drive 'normally' for 15minutes before loosing power again.
The problem has occurred since Georgia 5th August (air temp >40c) currently in Kyrgyzstan (air temp ~35c). Car has driven approx 250-450miles per day since then.
Other info:
There are no overheating warnings
Radiator appears to have reasonably even spread heat
Removing the MAF sensor does not affect the problem
Disconnecting then reconnecting the battery doesn't solve the problem
Only experiencing the problem during the middle of the day encourages us to think the problem is temperature sensitive. For example after 1hour of driving the car climbed 2,000m to 3,500m altitude taking 40 minutes (5am) no problem. Later that afternoon (12:30pm) the car could not move above 5mph on flat roads. By evening (8pm) car would happily drove up hills at 60mph again. -Contradicting this theory, previously the air temperature in the morning was 35c whereas now this is only the peak in the middle of the day.
Current theories:
Electric fuel pump is dogey
Fuel filter is blocked (doesn't explain why the problem varies during the day)
Possible electronic throttle peddle problem (throttle always shows an element of responsiveness even if there is no power to match)
Tomorrow we head for Kazakstan and hope to have an availability of spare parts.
Any help to solve the problem would be greatly appreciated before we continue onto Mongolia!
When:
Remedies:
Other info:
Current theories:
