Uprated Fuel pump in Fuel Tank ----------
Hi, this turbo is blooooody expensive business!! :)
I understand that i will need to change my standard fuel pump to a high flow rate pump (performance), can i ask from what other nissan model can i use for the turbo application to fit directly in my fuel tank?
J
so frank, as my fuel pump is only like 2 years old, so you reckon being a standard pump is adequate to run a turbo application then?
cheers frank!!
J
Only reason to change is if the stock pump proves to be problematic. Ed and I have maxed out a few stock pumps in the past oddly.
Ah ok, well my fuel pump was changed about 2 years ago, its that i spoke to Ed today to confirm a few bits needed and i did menion about the fuel pump and said it would need changing and possibilities that a Pulsar GTi-R fits of some sort!
J
