CMF_DanielW
» CMF MemberWhen I wire the coil in I need a switch to break the ground. This switch has three points ,two wires black and white both of them and the other is the ground which is its mount. This makes the k11 switch the little cylindrical part outside the dizzy. This looks like a capacitor which in the auto industry is called a condenser. This makes this a cdi ignition and has no power transistor which means I may have to work out the three wires on the transistor because the condenser won't switch quick enough for this transistor coil. Can anyone clarify this please.
