Uneven Tyre Wear
I have a problem with my k10, where the inside tread of the front tyres is wearing much faster than the outside of the tread.
I had the tracking checked and they said it is fine. They suggested it could be a problem with the camber. I spoke to a mechanic who said he didn't know if the camber is adjustable but didn't think it could be.
Could this just be a case of worn suspension?
I have been using 30psi in the front tyres - but I would have thought this would not have affected tyre wear.
Any suggestions would be helpful
Everything is standard i.e. wheels/tyres/suspension
No it doesn't. The steering wheel is out of alignment though - to go straight it needs to be turned to the right slightly (suggesting to me that either I or a previous owner has hit a kerb hard - I can't remember doing this though).
Perhaps something is bent?
The inside of the osf tyre is wearing at a faster rate than inside of the nsf tyre.
So if I am to suggest they adjust it for more toe in what sort of figures should I ask for.
Haynes says toe in as standard should be 2 - 4mm?
What would you suggest tyre pressure wise?
