2009 K12 Tekna - Intelligent key, central locking
I had the classic noisy central locking sound when locking my doors - turns out its a pin on the actuator that works loose and you just have to push it in again - that worked like a dream.
Door locked and unlock fine, from both outside and inside.
Trouble is, I got in this morning, shut the door then when I parked up the inner door handle wouldn't open the door. Central locking works fine (via key or internal button by the handbrake) and I have to roll the window down the let myself out by using the external handle (great stuff, very classy lol!)
So I took the door panel off and check the cable - there's on a single cable on this one that leads from the handle to the actuator - everything seemed in place and I even took the handle apart and pulled the cable with players (to simulate pulling the handle) just to check but no movement at the actuator
Not sure how to progress on this - anyone have any ideas/advice please
TIA
TIA
