Hi,
Need some advice for this horrible problem I have.
Basically, everytime I go over a speed bump a little quicker than usual, my driver side near the rear tyre makes a horrible scraping grinding noise. The car has not been lowered (yet!) and the shocks and springs seem fine.
Theres nothing on the underside that is damaged or hanging low.
However, I can see that the tyre sidewall is massively scraped on that tyre all around to the point where rubber is flailing off, so it pretty well damaged, so this must be what is scraping the arch (although there isn't any damage to the arch?).
The car has 25mm hubcentric spacers on the rear and I have 185 tyres on the rear. (This is the only non-standard thing in terms of this situation).
Causes? I guess I could just make sure to really drive slow over bumps but want to know why this has happened? Also, the rear tyres do look a bit cambered, like they are pointing outwards a little bit.
Will be grateful for any help as really stressing about this.
