Rudy WROTE:
"I worked for a tyre service for a while so I'll back up sikK11's little guide. I personally run the same pressures as RTK cause I reckon a couple more psi for low profile tyres.
I also check for total-toe wear, this will show up as wear on both inner or outer edges, and is the only easily adjusted part on a micra during a wheel alignment. steering wheel off center doesnt mean the total toe is necessarily wrong, if tyres are wearing even just remove and re-center the steering wheel yourself
tyre wear inner or outer on just one side is either a castor and/or camber problem. I would steer clear of tyre shops and use a front end specialist to do the adjustment and will require the purchase/fitting of camber bolts,castor kits, etc
I changed springs a few years back and have gone through a few tyres, I dont rotate my tyres, I have never wheel aligned it, the tyres wear fine, I dont fix wat aint broke
