Tutorial - How to change lights heater control panel
hey guys!
have this weekend change the lights from my heater control panel of my micra k11 1999. Very easy
1. Disconnect negative cable from the battery
2. Remove the central dash four screws
3. Then the heater control panel will be showed like this. (be careful with the radio connections!)
3
4. then you have the remove the switches, very easy just pull gently
6. now peel off the front of the fascia. Might be worth warming it up before you try and remove it with a heat gun or hair dryer.
7. will become like this. you dont need to remove completly
8. now remove the bulbs. they are 12v 5w headlamps.
9. Now you must replace the lamps and mount everything again and plug the battery.
(there is usually enough of the old adhesive left to stick the fascia back on again)
Easy!
