mine was from a twin turbo gto, so designed for a 1500cc petrol basically, so plenty big enough on the coldside.
yours will just have a bit more pumping losses off boost, ie 5 or 6 psi in the chargepipe and -5 psi in the manifold while cruising
just backpressure in the exh mani and chargepipe, a typical 4-2-1 extractor on a k11 will give a 5 or 10 hp gain over a stock mani, and a turbo setup will give a similar LOSS of hp (off boost) due to the restriction in the exh system of the turbine and its volute.
its gonna be worse on a small turbo and not as bad on a bigger one, but a bigger one is less responsive eh
Ahk I see what you mean there
So off boost I'll loss a little hp ? Yeah but not a lot to notice
So it shouldn't matter to much then yeah ? Will still have more power then stock and should be responsive to
yeh, small price to pay for 2 x stock hp innit
you lose some miles/gallon @ cruise basically on a turbo petrol engine, hence my current electric s/c tinkering
