just check the flow when its running eh (mine,s a trickle that would take about 1 min to fill a pint glass) where have you tapped into ?So you think it'll be ok just as it is?
I was just about to yell "FRANK!!!!!!!!!!!!!!!!"i forget where the breathers are on an MA tbh neil, CG,s have 2 or 3 iirc, and as long as you dont use the one with the pcv valve in (1 way valve) it should,nt matter really
The one at the belt end then Neil that goes to air filter housing?i forget where the breathers are on an MA tbh neil, CG,s have 2 or 3 iirc, and as long as you dont use the one with the pcv valve in (1 way valve) it should,nt matter really
Scrub that, forgot you have bike carbs and not standard carb/fannymouldThe one at the belt end then Neil that goes to air filter housing?
What's the worst that could happen??Cool, pending hangover tomorrow il give it a try
Ha ha!!Fatal explosion!
Sounds like a plan, you can always replace filler cap if neccesaryFiller cap did cross my mind
