turbo manifold and front guards
CMF_chuckles
Hi guys,
up for sale is a custom made turbo manifold to suit a NON A/C K11 Micra. The manifold Itself made out of 1 1/4inch (32mmNB) manderal bent steam pipe and tig welded on a custom exhaust flange plate and T2 turbo flange
This was designed to fit the biggest sized turbo that could physicaly be top mounted with little modifcations but still keeping it the same height as the engine so its nice and neat under the bonnet.
there is only a couple of modifications needed to fit this setup:
- Swivel dip stick all the way to drivers side
- Notch out radiator support pannel or wastegate bracket. (notch would only need to be about a 20 - 20mm square)
chasing $350 FIRM
Also have shaved front guards left with headlights $100
located brisbane southside
Dayne 0432 456 370
CMF_chuckles
still for sale guys will do manifold for 350 posted anywhere in OZ.
Plattsy - sorry didnt get back to you i dont get on the computer much so if anyone is interested ples call or txt and i will get back to you.
thanks
