CMF_Tseq
» CMF MemberI assume that this must have been discussed before but the old threads are gone so I'll have to ask again.
Intending to turbocharge a micra engine without reducing compression ratio and keeping boost low:
1)Can someone make an adaptor to the original exhaust manifold to mount the turbo or you have to fabricate a new one?
2)Do I have to change engine managment to alter ignition advance?
3)What engine management do you recomend?I need fuel,ignition advance and map sensor control.(Greddy-Apex'i for example)
4)Can I change the duty cycle of the injectors to spray more fuel and not fit bigger injectors?
