Hi guys,
I have a 2000 1.0 k11 dizzy. I am seriously considering turboing this little gem. I am in N.Ireland and 1.3 engine are like hens teeth... I am on a budget so was thinking of the old 5th injector set up? Is this something needed for these k11’s or is that overkill if only running 5psi?
I believe what I need is the following:
Turbo
Manifold
Intercooler and piping
FPR
Bleed valve
Running on a stock Ecu will I need a 5th injector for more fuel?
Is a thicker head gasket required?
Any advice is very welcome
Thanks in advance,
Andrew
Turbo
Manifold
FPR
Bleed valve
Thanks in advance,
Andrew
