Firstly, I had no manula with my micra.
Done a few jobs on my other car today so while the tools where out, the micra went up on axle stand s to look at the gear linkage........ :glare:
Nothing seams a miss.
So next step i think ill change the tranny fluid, as it finds the gears, just dont always pop in....
how much trans fluid does the gearbox hold on a 997cc Micra s?
Also wheres the refill point? I found the drain fine!:ghostface:suspect:
NEXT job, drivers door lock has been vandelised while the previous owners had it. :glance:
Is it a hard job to change the lock set, and iff I change the lot, can I stick the transponder chip in the new key and have no immobiliser problems? fwn
Ta very much like for any help!
