Trailing arm bushes
there are 3 different sizes iirc mike
Well iirc they one had a 50mm diameter and the other 46mm and both with 40mm depth...
I'm mainly after the diameter of the inside bolt hole frank so ox11ey can make some up for me
Looking at your photo, they look to be offset. I don't suppose you'd be able to tell me the distance between the bolt hole and the closest edge of the bush frank?
