Hi folks,
Just reassembled the micra after changing the stretched timing chain.
Started it up and code P0123 and P0223 which are both from the TPS saying the voltage detected is too high.
Have i plugged something in the wrong place, or do i need to do the relearn procedure stated here:
https://www.micra.org.uk/threads/ha...al-position-or-throttle-valve-position.66422/
I did clean the throttle body whilst it was off the car as it was fairly dirty, so this might have upset things, but I'm surprised by the code which says the TPS voltage is too high???
R
Sent from my SM-G960F using Tapatalk
R
