Toyota Starlet/Glanza turbo inlet manifold on a k11 questions
Seen two k11's with inlet manifolds off Glanza turbo's fitted....
What are the pro's and cons of this manifold
how does it fit?
What controls would be used? the k11 MAF/Idle valve etc or the glanza ones?
Also is it the EP91 type that fits?
I didnt think it lined up correctly, on stanis blog i think he made like a cutout for the glanza manifold to be welded to, but i could have miss sean/missread.
Other then that i recon the mani is decent to be fair.
Here's one Frank :) only I've been able to find so can't see where it's bolted onto the block
looks like an sr maf and tb. probably stand alone by the look of the work done or maybe some japanese magic box that makes the sr maf talk to the cg ecu
