Towing?
  • Thread starter Deleted member 29304
  • Start date
D
Hi All,
On Boxing day I needed a tow out of a thick muddy field and had a problem as my car doesn't have its towing ring attached to the under body shell. Does anyone know where I can get one from apart from Nissan direct and if I were to find a K11 2002 model in a breakers yard can you unbolt it or is wielded in place? If you wondered how I got out of the mud I remembered that in boot I had a pair of mud/snow plastic tracks to put under the front wheels and they worked very well & if you do employ these tracks attach them to the rear of the car so you don’t forget them.
Yours Peter 0003
Three points on the front, and one on the back. Have to dig around to find the front ones. Will be amazed if they are not there...
But is it JDM af?
