Torque setting on Rear Hub nut
Does anyone know the torque setting for the rear hub nut? Seems to be quite high. Doesn't seem to be the same as the K10, which uses 30 ft-lbs and then backing off nut 90 degrees. This is much higher torque. Anyone own a Pao service manual with the torque setting? Thanks.
the backing off setting is for taper bearings, and the high torque setting is for ball bearings
best to check what type you have
