h701micra
Deactivated Account
This is just a short generic guide I thought I'd throw together to answer the "how do I make it go faster" questions for the less mechanically minded
1. Strip interior
Its a good all rounder. It'll help with acceleration, braking and cornering. Take out as much as you like. More weight lost the better
Best of all it can be done in an hour or two
Cost: Free
2. Service Clean
While its had one elderly owner and a service history doesnt necessarily mean its performing at its best. A fresh service will help no end but dont stop there clean out all the pipes and electrical plugs. Dont be scared to take them off.. just put them back in the right place. It allows the engine to do its job better.
Cost: Free - £40 approx
3. Brake fluid
Of course brake pads and discs must be renewed when necessary but people often forget is the brake fluid. Dot 3, 4 & 5.1 brake fluid is "hygroscopic" which means it absorbs water. So over time becomes less effectives. Drain and replace this and you'll feel a confidence boosting difference in the brakes
Cost: £15 approx
4. An intake
Although a cheap air filter from argos seems appealing it can actually see you lose hp especially if installed incorrectly. The intake is very carefully designed by the manufacturer for that engine but it is still restrictive. Get a decent sized filter or a direct panel replacement. If you opt for a larger cone filter for example. Pick a cooler spot to mount it. Next to the exhaust is the worst place for it even if it is closest to oncoming air. Once mounted then use a pipe to funnel air into the filter still avoiding heat sources
Cost: Varies £30 approx
5. Exhaust
There's two small things you can do to make your exhaust helpful:
A: The cheapest option. Bring down undet bonnet temperatures by wrapping your manifold in exhaust heat wrap. This aids the intake of cooler air and helps your water coolant too as most rad pipes are by the exhaust
Cost: £20 approx
B: A small backbox. A 5.5inch super duper slash cut chrome full system made by 1000hp.com isn't the way forward. N/A engines need to retain the exhaust backpressure to aid in the 'scavenge' effect which draws air into the engine. A slightly bigger than standard freeflowing backbox will help the gas that needs to escape while keeping the harmonious back pressure throughput
Cost: £50+ approx
1. Strip interior
Cost: Free
2. Service Clean
3. Brake fluid
Cost: £15 approx
4. An intake
5. Exhaust
Cost: £20 approx
Cost: £50+ approx
