wait 6 months for all the bugs faults and coding areas to be fixed lol
Should I upgrade to Vista, it does look really clean and fun to use, but will it...
Run 3DS Max 8, Abobe Photoshop 9 and Dreamweaver 8 and Flash 8 etc?
Thanks for any help!
Darren.
It's not something you NEED so don't spend the money for it
For someone running Service Pack 1 of XP, I can't imagine security is a major concern for you Darren
I can get from POST to Firefox in under 40 seconds!
To quote A J Rimmer: "Simply brimming over with wrongability".Arnold said:I believe over 50% of the Windows network is still windows 2000! If it aint broke...
http://www.extremetech.com/article2/0 said:Networking support has been extended throughout the lifetime of Windows 2000 and Windows XP, but it was getting harder and harder for Microsoft to keep improving the old code. So for Vista, they started over from ground zero and rewrote the networking stack from scratch. IPV6 was hacked onto Windows XP in a pretty basic way, but it is built directly into the Vista networking stack in a much more robust fashion. Of course, IPV4 is still going to be the most common IP interface for quite some time, so all the new networking improvements are visible there, too.
The new networking stack has a much bigger focus on security, working better with firewalls to allow much finer granularity of which applications can use network resources in which ways, and it's made to stand up a lot better to network attacks. The built-in firewall in Vista is much more robust than the one included in XP Service Pack 2.
Vista would probably kill darrens laptop aswell due to the system requirements!
What even though it came new with a Designed for Windows Vista Sticker... jumping the gun a bit there Alan...lol
Had assumed it was older than vista that's for sure!
did you know vista was cracked within 24hrs of it going on sale.
There will always be someone out there that cracks the software, it always has happened and always will happen. It's just much less hassle if you buy legit copies anyway, as i'm sure the product keys will be blacklisted soon enough, leaving you with no automatic updates...
Yeah but what about the warm fuzzy feeling you get for running a legit copy of Windows?Not a great loss really when vista is supposed to be the most secure windows ever released! there 'shouldnt' be too many updates
It will be happened; it shall be going to be happening; it will be was an event that could will have been taken place in the future.
R05, before you do - just to make sure everything's okay, run this program:
www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
It will tell you if your hardware is up to spec and if you may have any problems with some programs
