my micra has 97000km and i thought i might look at doing the timing chain , i have been priced $500.00 for two chains 2 guides & 2 tentioners.surely genuine can't be the only source, i mean quite frankly that is rubbish.
There's actually a whole timing chain replacement kit available from nissan. It was released to address the premature wear issues the CG's original timing chains suffered.
THe UK boys let me know what the part number was, I think it was A3028-5F611. It included the whole kit of parts you would need to stick it all back together with a fresh new set of chain and tensioners. The pack is designed to save you money in buying all the pieces seperately.
It contains:
Both chains
Upper tensioner (spring tensioned when the engine is at rest and hydraulic when running).
O rings for the front cover.
U gaskets for the sump.
Liquid gasket to seal everything up.
It doesn't contain the lower tensioner or front crank seal.
You may not have to change anything yet. Oh yeh, $500 for the 2 chains and tensioners is far from "rubbish" its actually quite a good price. I think you'd be hard pressed to find timing chains and tensioners cheaper anywhere else. You have to remember that this isnt a rubber belt we're talking about here.
just recently got both chains for ~$180.00, so chain tensioner and gaskets for the extra money seems step to me? and are the tensioners recomended (since you'd buy the gaskets anyhow)?
oh, also i had my chains replaced at about 80000 and the odometer is now at 252000 and no noise from the chains(amazing!) (but will change them when the new head goes on, since I'm there)
The gaskets are recommended... Especially on an older motor as the rubber deteriorates over time.
THe bottom tensioner is spring operated and shouldnt need changing, the top one is spring operated when the engine isnt running and hydraulic operated (oil pressure) when running.
So thicker oil does very little for a noisey timing chain.
I no that Repco do not stock any timing chain parts for the nissan micra at all, only seals, so that is a bit of a bummer as I was looking into doing mine at some stage. So nissan wins again..
fred, how much was the timing chain and how much was the labor from that ~$180? Im hitting 200,000 within the next month and im looking to buy the timing chain kit from a auto shop (Odins ftw!) and ive got a mechanic mate that'll install it for next to nothing and a cheesecake (he loves cakes. )
Im guessing if i buy a 'better' quality chain it'll not make as much noise? Or last a little longer?
Toma if no noise do not worry. There are some Micras that do not seem to get the problem. Michael in Melbourne for instance has racked over 250,000 kl and no timing chain rattle at all.
