Chain too stretched real slack. No replies as to easy way, so I am going to detach gearbox mount to allow box to slide slightly to right, put slabs carpet and thin wood shims under engine and box, and slide engine off to see if it will come out, if so then decide to either swap engine with one with good chain, or replace chain. I thought more simple ideas would have been on this site due to the common theme of stretch chains, but unfortunately not. I am convinced that chain can be split and re joined with a bit of clever thinking, if, that is, the engine is not contacting the valves when turning over by hand.
