Now we have a proper blog system in place, this gives the opportunity to have your own blog for your car in the dedicated blog section.
This guide will take you through how to make your blog about your K10, K11, K12 Micra or any other car you might own.
When you have moved your blog, post back here, so we can delete it from the old blogs.
Kev
- Simply click the "Blogs" Tab at the top of screen underneath the "MSC Logo"
- Choose which section you wish to start your blog in, i.e if you own a K10, choose K10
- Over on the right hand side of the screen, you will now see "+ create new post"
- Give your blog post a title, if it's your first entry call it for example "Your Name's 1.2 Super S Micra"
- Create your post exactly the same as you do now on the forum, the options are all the same.
- You have options at the bottom that allow you to you to "preview" or save as a "draft" to edit and publish later.
- You also have options to allow replies to your blogs, select which one you would like to choose.
- Use the "manage attachments" button at the bottom of the page to manually upload from your hardrive if you wish too
Kev
