Hi I have a 2001 1.4 auto micra that has had this problem for a while and seems to be getting worse.
When you are driving and you let off the throttle the revs seem to stick for 4 to 5 seconds but not every time more noticeable when going downhill I have changed maf sensor and throttle position sensor but no change have tried tps off ebay and second hand bosch one there is another sensor on the throttle body with two Allen key bolts but not sure what that is? Have also checked throttle is going back correctly and this is no play in cable. Other than that the car starts fine doesn't stall runs perfect has just done 80000 miles has anyone had same problem or any ideas? Has recently had a good service oil change plugs air filter etc.
Running out of ideas
Any help would be appreciated
