hoodedreeper
I fitted my new rocker cover today,started the engine and the revs are higher on idle...you blip the throttle and the revs rise...but they either stay there or drop reeeally slowly.
Theres a bracket on the throttle body with a U shape cut out where the cable slides down into and on the cable casing theres 2 nuts.
1 nut close to me on the outter side of the bracket...then theres another nut further towards the end. Do i need to tighten the 1st nut to keep the cable in place? If not it slides up the bracket and come out.
I havent had to do anything with it before,but i moved it outta the way when i removed the rocker cover.
