Alienfish360
Awesome Dawson
Ok, am I correct in assuming the throttle body acts like a carb in the way it restricts and controls the air flow into the engine?
So using a bigger TB would increase the air flow? Which would increase performace?
I think I understand that, that's if what I state above is correct.
I'm currently driving a 1.0L are the internals of the 1.3 TB the same or will I gain from it? Are the mounts the same and will it be a direct swap? I hear NATS doesn't like it, can somebody explain what NATS does or what happens if you do this with NATS installed?
I've heard of people using the 1.6 TB is this from an Almera or Primera? If so does this require any modifications to mounts or TB?
Thanks in advance, couldn't find specific accurate answers in search
