CMF_Majiga
» CMF Memberi originally had in place my pwr barrel intercooler with a yamaha radiator and caravan water pump. Since then ive researched once the water gets warm it stays warm air cooling can only do so much. so..... I opted for this.
i got myself a jbj mini arctic 40gal aquarium water chiller to run off a 1000w inverter. using the caravan water pump and a 10 litre tank as a reservior. the chiller controls temps from 0 degress and 32 degress celcius. only requires 460 watts to run and will be hardwired to run only when the car is running so as long as i get a decent battery and the alternator is running properly it should in theory all work well.
