CMF_Rudy
» CMF MemberThe car "Putt Putt" is a daily driver, it is dead straight now, painted in 2pac, and the plastics will be painted soon as i get a new rear SupS bumper, car has king springs and new shocks and i just got 14s for it which will get 185/55/14s this week
I am going to be the owner of an n14 wreck soon which i am getting the front discs from to match up to the disc brake rear end and larger SupS booster sitting in my shed. I also intend to use the gearbox for longer legs as my car does alot of highway driving, provided the driveshafts are not to hard/expensive to sort out
Engine wise is what im trying to sort out in my head, i already have extactors, larger exhaust, and pod filter.
The next stage im planning is ga15 thr/body(already got), bigger injectors(thought i was going to use the ga16 ones but just read that only the uk ones fit??), and reground cams, I intend to use my std bottom end as it doesnt use oil/blow smoke and i have two spare ones
does anybody have any advice on the cams or injectors it would be greatly appreaciated, or if you see any other holes in my plan could you point them out
thank you... Rudy
thank you... Rudy
