CMF_kovert.k11
» CMF Memberthanks to turbo-march-rolling-shell's time, expertise, patience and determination, and my hard-earned funds, we have managed to produce a thing of beauty.. many of u may be familiar with the setup from when tmrs was running it, but he has tuned it to perfection, and managed to squeeze some more power out of it... 154.5 kw to be exact! the breakdown of what has been installed is as follows:
stock cg13de
tomei 256" in/ex cams
custom bellmouthed sheet metal intake plenum
sr20de throttle body
ca18det injectors
custom motec fuel rail
petterson dry sump catch can
sard fuel regulator
walbro 550hp fuel pump
ihi vf30 turbo
tial external wastegate
custom steam pipe manifold hpc coated
3' dump pipe hpc coated
3' stainless exhaust with 200ppi super expensive highflow cat
3'stainless cat back with 3 1/2' titanium muffler
custom pwr intercooler
custom intercooler piping/intake piping
hks air filter
turbosmart vee port bov
turbosmart e-boost2
autronic sm4
autronic 500r cdi
hks type-1 turbo timer
mercury marine cdi coils
defi oil temp/oil press/water temp gauges
comrade c's short shifter kit
heavily modified exedy button clutch
n15 pulsar gearbox/sr20 CV's/custom driveshafts
jun 4.3kg flywheel
turbosmart fuel pressure gauge
custom alluminium overflow bottle
custom vaccum distribution block
hpc coated alternator
bcrew's coilovers with 7/5kg springs
rear strut brace
whiteline panhard rod/sway bars/anti lift/camber bolts
jap (?not sure of brand?) drop links and stubby end bolts
full nismo bush set
front control arm tensioners
gti-r calipers and rotors
nismo smoked side indicators
nissan taiwan march LED tail lights
hkb boss kit/OMP 330mm steering wheel
watanabe 14X6.5 lightweight rims (with **** nexen n2000 195/55 tyres)
rolled rear guards
still plenty of things to be done... tmrs has already started building a forged block for this with customised internals as per his specs.. built with the ability to run a NOS setup in the future... also have p/s setup and jic carbon fibre strut brace to go in.
aesthetically, car will get a full respray, with the interior stripped out of it, a mulholland 7-point roll cage, & OMP Grip racing seats to be installed. jdm front and rear bars and nismo front grille will end up going on, along with crystal headlights.. am also waiting on some aspect fpr front guards and a mulholland front lip spoiler. 15X6.5 volk CE28N (powder coated black) with toyo proxes r888 195/50 also to go onto the car.
has been an adventure for all involved building this thing, but the result is worth the grief/hurdles that were encountered and overcome..
massive props to turbo-march-rolling-shell... he's not only a good bloke and quality mechanic, he's a craftsman...
stock cg13de
ca18det injectors
sard fuel regulator
ihi vf30 turbo
hks air filter
turbosmart e-boost2
autronic sm4
autronic 500r cdi
jun 4.3kg flywheel
rear strut brace
full nismo bush set
rolled rear guards
