CMF_penpusher
» CMF MemberPretty sure I know what the problems is but will run it by others on this site first.
When driving the car it stutters quite aggressively and makes the car jerk something terrible. When at the lights (or not revving it) the revs drop to zero and it stalls. I think it is worse the hotter it is. The TB has been resoldered previously (not sure how long ago). I assume it is a TB issue, so will look into purchasing a new one on the net. Apparently others on the site have bought them without complaint.
Is replacing the complete TB unit a job that a relative novice can do,assuming they have the Haynes Manual ? Do you need special equipment to set it up/or is setting up tricky and best left to a motor mechanic. i.e what are the chances of me f*cking it up ?
