CMF_imutluay
» CMF MemberI have a 1996 immobilised 1.3 CG13DE Micra K11, I experienced problems when placing P10 Primera Throttle Body, Injectors & ECU.
I think this is because of the immobiliser, because with the K11 ECU, car works fine with P10 injectors & P10 TB except a rich fuel/air mixture, you can see it through the exhaust.
With the P10 ECU, immobiliser light signals.. Fuel pump doesn't work, which I start the fuel pump manually, etc.. did not help as you can guess because of the immobiliser.
I think replacing the wiring loom with a non-immobilised early 1992-1995 Micra is an option which I couldn't find in Turkey at the moment. Can anyone has a better idea than changing the wiring loom? maybe some of you experienced the same problem.
Regards from Turkey
Regards from Turkey
