Switch AM/FM Aerial Mast Antenna Roof k11 - 1999
A doubt someone has switched the radio antenna ?
My have the back and is already a little worn out and wanted a new
Has anyone done this process ?
Thank you, hug
Do you mean you want to replace a broken roof aerial. If so, then you need to lower the roof lining slightly by unscrewing the sunvisors. I think I also popped off the piller trim pieces and a bit if the door seal. I didn't want any creases in the roof lining. You can then get to the fixing at the bottom of the aerial. If its just the antenna then it screws out and you just screw a new one in.
I have a front mounted aerial. I got one of those blaupunkt windscreen aerials really good, as alternative to ripping out the headlining!
