Suspension Help
Dave Bull
OK guys I need some help...
As you may know, I am in the process of building an SR20DET powered K11, to join my current E15ET(stroked to 1680cc) powered K10.
The K10 is sorted for suspension, thanx to my Almera GTi donating it's rear Koni coilovers, but the K11 is in dire need of some beefier suspension.
I have a feeling that the majority of kits available for the K11 are lowering sets.
I have no desire to lower the car, but actually raise the rear end and make it as hard as possible.
Therefore I need to know if there is a damper and spring combo for the rear or just damper set (as springs aren't as hard to get) to give a real hard setup.
Koni maybies?
Please help guys.
Oh yeah...both these cars are setup for drag racing, so no handling issues here!
Dave
The K10 is an all out drag car really that can be driven on the street.
In theory it should run 11's...
Not bad for something that has cost about £150 to buy and build!
The K11 however is a car which I plan on using everyday...and I promise will run 11's!
Dave
tbh i dont think that konis will be able to be set up stiff enough for your requirements however they do, do a kit for the k11.
ive only heard good things about the bilsteins tho.
I have the rear setup to my requirements now...
400 lb spax springs on Leda adjustable dampers!
STIFF as a gallon of moonshine!
