superlite wheels
CMF_sikK11
You will need to check the centre hole to make sure it is right.but you should be able to get it machined out a little if needed as well. But as for that it should fit. Beware though good tyres in a 13'' are hard to find. Most performance tyres dont come in such small sizes.
CMF_Jon (2)
Why not give performance wheels a call.
I'm pretty sure the wheels come as a blank and get drilled to what you want.
VIC - Performance Wheels
42 Mickle Street
Dandenong VIC 3175
Victoria - Australia
Phone 03 9706 4244
Fax 03 9706 6922
As for tyres, I had no drama's finding decent 13" when I ran them on my mini
CMF_1300cc
Jon WROTE:
"Why not give performance wheels a call.
42 Mickle Street
Dandenong VIC 3175
Phone 03 9706 4244
Fax 03 9706 6922
they're wholesaler....i rang them already and was told to go to any dealer.....
CMF_1300cc
42 Mickle Street
Dandenong VIC 3175
Phone 03 9706 4244
Fax 03 9706 6922
CMF_sikK11
All the sizes in that tyre are all skinny with high sidewalls. If you push them you will see massive side wall flex. I would not go 13's for that reason. I get enough with our 185/55R14's now. We run Bridgestone Potenza re001 which would be the best tyre i have used and i used to work in a Tyre shop for over 3 years.
CMF_chargeR
I don't find 13" wheels to be too bad on track :). The car flops about a bit on the tall skinny tyres, but it's slow anyway. I think that those wheels in 13x6 +20 would look and fit pretty well on stock guards with a 185/60R13. Go for it. Put some Toyo R888s on them, the sturdy sidewall on them should help compensate for the tall sidewall.
