CMF_White Knight
» CMF MemberWell its an ongoing project.Belt slip is a bit of an issue.
Means if I really tramp it I sometimes get slip and loose a bit of boost.Drops from 12 down to around 10.
Slip is on the small supercharger pulley. Not feasible to put a bigger pulley on as it contains the magnetic clutch plus a bigger pulley means less boost.
So seeing where another drive pulley can be installed so more of the belt has more contact surface area and hence more grip.
Have replaced the belt twice now with a new one but after about 2000 kl start to get slip. Adjust it up on the tensioner but after a short time it slips again. So it aint the belt but more lack of grip.
I am going to patent Whitey and all its mods one day.Apart from the above irritation it running as sweet as.
