Super S temp gauge not working
Demarest
I am in the middle of installing my super s dials into my L model,
Every thing works as it should (the rev counter, the warning lights, the fuel gauge, the back illumination lights, the clock etc)
BUT
The temperture gauge doesnt.
I toke the car for a run with the old temperture gauge (the one that has the temp only) and the needle raised to about half way.
When i got home i plugged the Super S temperture gauge back in (the fuel and temp in one gauge) to check if it was working and the needle on the temperture gauge just stays in the postition as if the engine was switched off
Did anyone have this problem when installing Super S dials into an L model?
And does anyone know how to fix it?
might be a problem with the gauge
mine used to work fine then one day it started working back to front, when engine turned off it would be above the danger area and then went down, weird i know
