Super S poor running
CMF_demonical
When i push it at wot 1 and 2 are fine but in 3rd there some kind of kangarooing it stall's then shoots up and again.
The engine is a 1.3 CG13DE with slightly ported head , CG10 pistons with brand new piston rings , stock exhaust maniford de-cated + 50 mm pipe and backbox , GA16 black injectors ,the stock airbox and a brand new lambda sensor. When i unplugg the lambda it seems to run better , that's why i bought a new one butt nothing changed.The MAF is working 100 % it got off a perfectly running micra
CMF_frank2
the only problem is that the ecu will probably drop out of closed loop when you are cruising and have to add a bit of throttle when you come to a hill, and you will probably get acceleration enrichment all the way up the hill (and use more fuel)
it will probably depend on what injectors you run, i get on a lot better with the later topfeed ones personally
an option would be to fit a switch @ wot only, or just a bypass switch
