CMF_penpusher
» CMF MemberThe Super S is slowly coming back to life after an accident, however i need to replace the hub assembly as it broke during the accident. I was going to replace the whole unit (from inner to outer driveshaft) from another wrecked non super s car,however I have then seen a thread on here about the Super S ABS driveshafts and or the CV joints being different because the CV joints have some sort of ABS ring on them ?
Can somebody confirm whether the actual driveshafts are different or whether I can just buy standard a CV joint for a standard micra and then swap onto it the ABS ring from the one I have onto it or is the CV joint itself different in order to accept the ABS ring ?
If it the shafts/CV joints are totally different, where is recommended for me to buy these parts and the approximate cost please.
