cisco
» CMF MemberBe honest and tell us what the silliest most embarrassing things were that you have done on your car that you thought at the time that it was cool or the best thing to do.
I'll start:
You know that big side plate on the gearbox that has about 8 bolts holding it on? The first time I changed my gearbox oil, I removed all 8 bolts and the entire plate to use it as an oil filler hole. This plate thing I think is like a cap for the back side of a main bearing, so its servicable etc. But there's not much room to poke anything through, so a fair bit of oil spilt out, and I thought I was doing the right thing using the "filler hole". To make matters worse, I had bought a $99 gear oil pump to specially pump my gearbox oil up into this bearing plate access hole.
Ridiculous! Now I have a $1 piece of clear plastic tube and I know to syphon it into the real gearbox filler hole and it takes 2 seconds!
Allright, own up..
I'll start:
Allright, own up..
