stunnly loose gear stick
hi all
got a problem. a loose gearstick. i was driving allong went to change gear and sudenly the gear stick became loose. wouldent go in to 1st or 3d but would go in to 2nd and 4th. managed to get home lol. i have read i could be a broken spring!?
Any one else had this prob and found a way to fix?
Cheers dudes
micradrivr
might be worth checking the gearchange rod bolt is,nt hanging off, as a result of the clutch repair
cool. just drove car and g box is fine. can get in to all gears just have to push further. car jacked up now. looking how to get to under the rod. have to move exhaust and heat plate i think? checked where rod connects to box and looks fine.
im still geusing spring?
any help is appreciated
thanx
just fixed it. slide heat shiled across so as to access under the rod. descovered 1 broken spring and 1 missing bolt! put new bolt in and bent spring so was repaired and hooked in place.
first time under a car
Chuffed LOL
