Strut top mount
My top mount is knocking and I was considering replacing it when I came across this. Would this work or do I need other parts or is it easier to buy the full top. I can't buy the top from Scrapyard's here :(
the last bit of rubber you can see in that top mount wares down letting the metal plate below to be loose.
tighten the rubber up again stops the rain :)
If you take out the top mount you will see it only need a few millimetres raising to tighten back up.but the flimsy tabs holding it all in look suspect.
