Steeringwheel vibration at 100 km/h
So my steeringwheel vibrate more the faster I go up til 140 km/h(85mph), above 140km/h it doesn't vibrate as much.
Car got a alignment done om the front but it was mostly camber that need to be adjusted (car was lowered 2 years ago) and the wheel has been balanced.
It start to shake more when my mechanic change my tie rod end.
Mine does that too, at the exact same speed, I've just gotten used to it
Things to check would be tyre age (the metal inside can warp) as well as the wheel balancing
You've already done wheel alignment, so probably not that
Had this too once, stumped me for ages until I found all the dam potholes had caused a slight bump/lump damage in the tyre tread
